Still winter here and the farklizing is just beginning for me. Installed the Audiovox CC last winter and it worked fine all last season. This winter after pulling off the plastic to install a quartet harness and cigarette lighter type power jack, this is what I found.
The CC vacuum cannister that I built out of some old vacu-flo piping (2 inch diameter, styrene? plastic, about 5 inches long) totally collapsed. BUT, it still holds a vacuum. It must have deformed over time. It was tucked up behind the left side of the dash, so I don't think that heat was an issue. This would have been a real pain to fix on the side of the highway somewhere, raining probably.
I will replace it with some sturdier ABS drain pipe plumbing shortly. Lots of hills here in the west, and I tried last spring with and without the cannister. It made a difference.
Lucky me.
Lucky me.
