I wouldn't leave it there. You don't need that thing breaking while you are moving at sixty MPH and it punctures your tire causing a rapid deflation, gets jammed in your brake, rips out the brake hose or ABS wiring, etc.. You never know what will get damaged when a foreign object is introduced. When you are moving at speed there is a lot of energy there.
I would get some nice over-weight friend to sit on the passenger seat, or otherwise compress the rear spring as much as you can using ratchet straps or whatever you can come up with, and get that thing out of there under controlled conditions as opposed to waiting for it to break at an inopportune time and it bites you.
