I believe the abs system changed on the ST1100. What year did the change take place if what I have been told is true?
Best regards Mal
Best regards Mal
Mal, you should have a plate/sticker under the seat which will identify the the model, mine for example is a ST1100W = 98.Hi. My forks are 43mm so that confirms it. I was concerned that the bike had stood in dealer stock for a long time., which can happen here in the UK.
In the vicinity of HardKnott Pass by any chance?Yes, I found out what it meant a day ago. It's an AY which I believe is 2000.
Mal, also up north in Lancaster.
One of these days I am going to retire and get serious about motorcycle riding!Hello again. Looking at your recordings you certainly get about some!
Yes, an ST1100AY is what Honda calls a year 2000 ABS II model. The Y should also be in the tenth position of your frame number (plate).Yes, I found out what it meant a day ago. It's an AY which I believe is 2000.
