I am new on the forum but have been reading it for a couple years to find some help with some issues on the ST1300's.
I currently have a 2009 Police model with only only 16,000 miles on it, and the ABS light is flashing.
The bike has always been in the desert so there is zero rust or corrosion on any of it.
The ABS light comes on when the key is turned on and stays solid until it is ridden a few feet at which point it flashes and continues to flash.
The ABS rings on the wheels are clean and not broken.
The ABS sensors are clean.
The tires are the correct size and have the correct amount of air in them.
The secondary piston in the left front caliper that applies the rear brake when the front brakes are applied is clean and working properly.
The F1 light comes on for 2 seconds when the key is turned on then goes out and stays out.
The ABS main, front, and rear fuses are good and have no corrosion on the connectors.
The brake sensitivity is exactly the same as one of these bikes that has properly working ABS.
My fuse boxes do not have letters on them designating what the fuses are for, and instead, they state what they are for ie, "ABS main, ABS ft, Headlights, Battery, etc
I found the link below on how to get the codes from the ABS light to determine what "may" be wrong, however, there are no lettered fuses on my bike, so the procedure does not help me, and the test procedure appears to be incorrect in the "FAULT CODE CLEAR" or "REASSEMBLY" section, because it states to reinstall fuse "M" in both sections which can not be done in the "REASSEMBLY" section because it was already reinstalled in the "FAULT CODE CLEAR" section. It also does not state to reinstall fuse "H" before reassembly.
stwiki.notonthe.net
Fault Code Clear
Begin the Fault Code Check procedure above.
While the ABS indicator is blinking out the fault code, reinstall the M fuse.
Verify that the ABS indicator remains on after the fault codes are indicated.
Continue the procedure.
Reassembly
Install the M fuse.
Install the left side cover.
Install the front and rear seats.
Thanks in advance for any help.
ABSQuickGuide < ST13 < STWiki
Fault Code Clear
Reassembly
Install the M fuse.
