white on yellow flash turn signal LED bulbs?
st11ray
charlotte, nc
'06 ST1300
7189
This is the brand that I have. I found my old packaging but I can't find a part number on it. I don't know if these are the right part number but they look like mine.
st11ray
charlotte, nc
'06 ST1300
7189
You will find everything you need to know here.
STRider
Oregon
2012 ST1300A
50
These worked well for me.
iBrightstar Newest Super Bright 7443 7444NA Switchback LED Bulbs
Word to the wise. The space inside the shell is limited - the depth specifically - and some sellers claiming to 'fit' the ST1300 seem to be going by simply matching the bulb's base type, 7443, without accounting for the length of the bulb.
Obo
East Coast Canada
'03 ST1300A
These were the bulbs I bought:
I'll second they were a tight fit (long) and almost (or do) contact the front of the clear lens. Try and find the shortest length you can and ones with a width no more than the width of the bulb opening. They *should* not be wider but I've seen some strange bulbs before that go into a larger board vs a holder like on our bikes.
As others have said you'll need an LED compatible flasher relay to prevent the hyper flash issue with the OEM relay.
Really any 2 pin LED relay will work. Having a matching connector plug is just a plus. Most won't fit in the OEM bracket holder but you can just stick them in the relay area without concern.
STRider
Oregon
2012 ST1300A
50
Just for reference... The depth from the base of the receptacle to the interior wall of the turn signal lens is approx. 61mm, not accounting for the thickness of the O-ring around the bulb base.
These bulbs I bought on ebay, specifically listed for a Honda ST1300, do NOT fit at all. Many puzzling e-mail exchanges later with the seller resulted in a return and refund.
FYI...
STRider
Oregon
2012 ST1300A
50
Montreal
2009 ST1300A9
@cdnemsguy seemed really pleased with the ones that he installed and didn't report any complaints or problems with them- Auto EC.
Now that it has been three years, maybe he can give us an update on them.
LSAC, AB & Indio, CA
2005/06/07 ST1300
Absolutely Andrew. I would certainly buy these bulbs again if I could find them. I got them off Amazon and they are no longer available. They have be problem free and still performing flawless after the years. This was after the install 3 + years ago...
And today...
Now just to find them again. I have some others coming from Amazon in the US as I couldn't these or the ones coming in Canada.
https://www.amazon.com/dp/B07PFJR6QR?psc=1&ref=ppx_yo2_dt_b_product_details
These are recommended from another member and look white. IMO the thing to look for in these lights are 7443, color 6000-6500K and make sure they are not too long for the holder.
2005/06/07 ST1300
Just to add to my post above, I just received those new switchbacks as in the link above and have the comparison photos for you here. On my black beauty are the 3 year old Auto EC that I can no longer get, and left red baron are new LEDS. Both are equally very impressive. The new set edges out the older set, but durability has yet to be seen. I will let you know in 2024 ;)
STRider
Oregon
2012 ST1300A
50
Not at all surprising @cdnemsguy. The technology is in the design and manufacture of the SMD LEDs. That long one I showed in Post #11 was a crudely built assembly of extruded aluminum and a loose circuit board in that unnecessarily long body attached to the base at one end and the panel of LEDs at the other. I'm glad it didn't fit so I could return it.
As soon as a cheaper, faster assembly process can be implemented, they'll switch from that design you knew and trusted to something else faster than you can spit. I'm glad your AC Auto ones continue to work well for you. I'm hoping I'll be able to say the same about the iBrightStar ones I bought in several years.
Venango County, PA
And today...
How did you mount the light that is just above your fender?
2005/06/07 ST1300
I found this inexpensive thin light from Princess Auto in Canada here. It has a mounting bracket with it that all I did was add a spacer for each bolt and mounted it by bolts through the fender, far enough back that it just clears the fairing, but high enough it helps with lighting the road and ditches. Its not the best out there but works. I also put a relay and switch on it so it comes on with Hi beams only controlled by the hi/low switch.
