I'd like to know what your antenna preferences are and why if you don't mind. I've just replaced my J&M CB with a new one and learned afterwards that it was an antenna problem and not the radio. My antenna coax is one of those with the ring where 1 side is the center pole and the other side is the shield/ground. Either by tightening the through-bolt, wrong assembly, or natural failure - the coax has an intermitent continuity break at the ring. I'd tested it last week before ordering a new J&M unit and it had continuity, but when I intalled the new unit yesterday and checked the SWR it was way off. I checked again and the ring's center pole is open. This will be my 2nd coax and I am likely to blame for it's failure, but I don't accept said blame for the failures I've had with the 2' fiberglass antennas I've had to replace due to broken wires inside the mast themselves.
A 2nd question would be whether the suggested antennas will work with the same ring set-up as the J&M units or do I have to replace the coax and mounting systems too?
Inputs appreciated! Thanks, Gordon
