ST-Owner Group Members,
Just want to start out by thanking all of those that have provided help already and sent over resources on how to track down this fuel pump / electrical issue I am dealing with on my '09 ST1300PA.
Using the fuel pump troubleshooter guide, I was able to figure out the different relays and which components do/don't have power.
Specifically the brown 12v from the fuel pump is not getting power while the bank relay sensor is getting all proper power/grounds.
Following the answer sheet I had been provided with, it states that my issue is being caused by a bad switch somewhere else on the bike, kickstand or clutch, neutral safety switch etc. I have been checking these but finally determined that the issue is likely the ECM itself.
I see how expensive these things are online and am ready to throw in the towel and pick up a new ST altogether.
The trouble that I am having is the fuel pump is not priming. If I jump the ground cable on the relay, it does get ground and you can hear it prime when I turn the on/off switch.
Is there anyway I can bypass the ECM or any other fixes for this besides replacing the ECM itself? I understand that the ground connector is within the circuitry of the ECM and it is sealed and can't be fixed.
Any help is very much appreciated.
