2003 ST1300A with 128,000 miles on the clock. After a clutch failure last week I rebuilt the master cylinder only to discover that it was a pinhole leak in the clutch hose itself. The leak is located in the flexible part of the clutch hose in the vicinity of the steering head; it soaked the front of the bike in clutch fluid. Looking up the part, it appears that the clutch pipe is one continuous line from the master cylinder on the handlebar to the slave cylinder on the back of the engine. Has anyone replaced this part without removing the engine? I found the ST1300 - Clutch Slave Cylinder Replacement article by MaxPete, but I'm not sure about replacing the pipe itself. Any advice is appreciated. Thanks, DP
