I did a clutch fluid flush and found a part loose in the reservoir. Turns out it is part #8 on the parts fiche called “protector”. I didn’t put it back at the time as I had no clue where it went. Is this a necessary part? What’s it’s purpose?
Dean, please, I'm having a pastry and coffee and you're talking about your spooge hole. SPOOGE HOLE, YUK.Does anyone other than my Yamaha XS friends refer to this as the "spooge hole"?
I believe that it is a friction-fit (press in to fit) component, you might be able to put it back into place using a pair of tweezers or needle-nose pliers with an offset at the end....I think I'll just hang it on the 'extra parts grave yard' wall.
Yes, just snap it back in place.I believe that it is a friction-fit (press in to fit) component, you might be able to put it back into place using a pair of tweezers or needle-nose pliers with an offset at the end.
Michael
If you find my speedo drive screw on that wall, send it back will ya.Yup the first squeeze of the clutch handle let me know I was up for a fightThanks for the responses everyone, I think I'll just hang it on the 'extra parts grave yard' wall.
Not if they're a mature adult.DeanR said:Does anyone other than my Yamaha XS friends
