Since the weather has turned colder here i have been having cold start issues - no start - poor engine idle - several times had the engine die while stopped. The problem would go away and not happen for several days. I never had an FI code in the ECM and never had a flashing FI light. I changed the spark plugs, took the air cleaner assy off and tightened up the throttle body rubber boots (what a PIA that was!!!) - while in there i synced up the cold start valves - i checked the 5 way connector and hoses - they were clean inside with no evidence of gunk - seemed to be ok for many days and then the problem would be back. I searched the forums here and came upon the MAP sensor issue a few others were having. A few did have the 2 blink FI indicating the MAP sensor and some had no error code. The MAP sensor is over 100.00 so i got one from ebay from a low mileage honda (the map sensor is on about all fuel injected hondas) for about 25.00. I replaced it and i have a new running motorcycle now! The cold starts have been perfect - no more low idle problems - no more issues what so ever - so if you have been having problems like mine and have no ECM codes the MAP sensor just might be your issue as well.
Mike
Mike
