Oh great ST Hive-mind...
From a Throttlemeister application chart I found here, I see there's a difference in the part numbers between ST1300s with and without the Honda Heated Grips (the OEM version I expect).
Can anyone tell me the difference between the 'AHR4' and 'AHR5' parts? I have a TM on my ST1100 with Helibars so I understand how a TM works and the parts involved.
The only difference I expect might be the specific stack of spacers and shims to space the adjuster from the bar-end/throttle tube?
Unlike throttle locks that clamp the grip near the control pod (Vista cruise, Atlas, etc...) where the heated grip wire might interfere with its operation, the TM is at the bar end. What's different enough there to warrant a different part? Is it the friction sleeve design?
I intend to install the Koso Apollo heated grips and want to understand if I'm missing something.
Thanks!
Tom
Honda with Stock Handlebars and Heli Bars manufactured after January 2004
Thanks!
Tom
Model | Year | Standard | Heavy |
ST1300 | 2003-09 | FT & AHR4 | FH & AHR4-H |
ST1300 w/ Honda Heated Grips | 2003-09 | FT & AHR5 | FH & AHR5-H |
