DIY Exhaust Slip-Ons
Ohio
In my Introduction post I said that I really did not like the factory slip-on mufflers. They are too quiet, the tone is like a sick moped, and they do not fit with the bike. What I mean is that the OEM slip-ons are highly polished odd shaped mufflers. The shape forced my wife and daughter to stress so they did not get burned when getting on/off. In addition, there is nothing else polished on the bike, so they really stick out like a sore thumb.
I looked around, but I could see spending at least $600 for the aftermarket replacements. The universal slip-ons were not much better, and still pricey. So I decided to fab my own and spend less than $150 for everything.
First, I needed to decide what muffler I would use. I remember how my brother's V4 Interceptor sounded with a pipe. I can see why Honda choose to tone down the exhaust as not everyone will like a louder V4. My goal was to add a deep sound and also keep the volume in check. The solution was to use auto glasspacks.
Why auto glasspacks? Well motorcycle slip-ons are basically the same thing. I just need to be carefull to add noise control while allowing the ST1300 to breath better and sound better. The muffler I choose is 22 inches long, and it ends at the back edge of the saddle bags. I also choose a small core of 1.75 inches to keep the sound under control. The smaller ID and longer length will aid in sound control and not greatly impact the bike's performance. Here is the parts list:
From www.jegs.com
Patriot brand Smitty's Mufflers (Jeg's PN 545-87502) $30/each = $60
Jeg's brand Satinless steel muffler clamps (PN 555-30724) $11/each = $22
1 Can Krylon High Temp Paint (WalMart) $5 dries very quickly
2 Exhaust Hangers (Autozone) $3/each = $6
2 Exhaust adapters (2 inch ID x 2 inch ID Autozone) $2.50/each = $5
1 Exhaust Pipe Repair Kit (2 1/8 inch Autozone) $6
4 HD Worm Clamps (ID 0f 2.5 inch from harware store) $1/each = $4
You can see that I plan to use flex pipe to connect the mufflers to the OEM pipes. This was only temporary to see if I liked the system and until I could make it to a muffler shop for permanent pipes. The muffler shop charged me $10 for the pipes. Total investment of $118 plus taxes.
Installation was easy. First, remove the OEM mufflers and gasket from the pipes. Second, position the muffler where you want it and mark the muffler for reference for the clamp position. You will use the rear mount for the clamp. Third, install the exhaust connctor (2 inch ID pipe stub) into the OEM connection and tighten the OEM clamp. Fourth, measure and cut the flex pipe. I used the HD worm gear clamps to secure the flex pipe over the muffler inlet and over the pipe stub. Using the worm gear clamps makes it is easier to disassemble, does not distort the flex pipe and provide a leak-free connetion. Use the 3.5 inch muffler clamps around the outside of the muffler, and the hanger to secure it to the rear mount of the ST. Note that the hanger has a bent metal rod which will need to be cut off. You may also want to drill different holes in the metal strap to allow the muffler to be positioned as you like. Repeat on the other side.
Once everything was checked, I started the bike. I was very happy with the setup. A quick test ride did not present with any excessive noise; just a nice mellow sound. When I returned, I took everything apart and painted it with the high temp Kryon paint. This stuff dries very quickly and touch ups are also quick. I put it all together and drove to the muffler shop for the permanent pipes. In retrospect, you should probably wait until you return from the muffler shop to paint everything. I am still looking for a tip, and I may change to a fully stainless steel muffler, depending upon the service life of this setup. I'll take some pics tomorrow in the day light and post them. Good luck on your build!
Would like to see pictures and determine if this negatively affects performance of the bike. I too do not want to spend 6-900 dollars on an exhaust system. But I also do not want it to look bad.
Thanks. Looking forward to pictures and comments.
If you go to jegs and look up the part number, they basically are cherry bombs. Look to be similar to the ones that were popular with the valk guys, I had some on mine and they did sound good on a 6 cyl bike...
It would be cool to also get a sound file.
As I said above, I will post a few pics tomorrow. I don't see how this will hurt the performance of the bike. We have a closed -loop fuel and timing system with oxygen sensors. The computer will adjust to changes in backpressure, etc. Also, please remember that this was an experiment. You can customize your system with any mufflers you want. You just don't have to pay $600+ to do it. Thanks.
Isn't removing the catalytic converters illegal or something? Not that I want to do it but just saying. A while back there was a thread here where someone fitted a pair of $30 stainless cans from the auto parts store and this thing with federal emissions came up.
Pretty much anything you do that modifies the bike where it puts out more sound or emissions is illegal.........give or take some legal mumbo jumbo..:D
My opinion: if it aint' loud it won't get looked at. Denver (iirc) has a new law that says the OEM info has to be on the muffler. If they don't look, ya don't get caught.
Each state and locality may have noise standards in addition to the federal laws This mod isn't nearly as loud as you may think. In fact, I can barely hear it when I am going down the road. As for the cats, I'm not sure if they are required. I could find any requirement in OH for motorcycles, but may for CA and other states have have adopted similar CARB standards. I guess I have not seen a Harley or any other motorcycle in OH with cats.
I have Staintunes on my bike and just for those that don't know,,, they do not have the Cat's in them... A big part of why the weigh 16 pounds less than stock I am sure...
Only downside they have is???
People following you will get a strong smell of Gasoline on when you are decelerating... That is the main job of the Cats...
Putt clued me in on this as,,, out in California I thought I had something really wrong as anyone following me smelled gasoline...
Dr. please do some temp comparisons. I've wondered all along if the cats have influence on the perceived heat levels.
I only recorded a couple of infrared thermal readings, and my slip-ons were at least 28 degrees F lower after riding for 15 miles. I do not have any real-time data though. The smaller size of the slip-ons and the lower temperatures translate into lower emissivity, which is a very good thing! This may be why Honda choose the size and shape of the exhaust mufflers. They may have needed the size and shape to help radiate heat away from the bike. Something to ponder...
Photos! These were taken with the flex pipe setup as you can see.
Looks great. I wonder how it affects the hp. I don't know about making a custom slip-on exhaust, I like the quiet stock one, but I now wish the exhaust on my 07 :07biker: was black.
Not bad, but it looks like they are "more" in the way for wheel removal. You can't beat that price though. I thought one of the other sets didn't require removal of the exhaust to get the back wheel off.
You could easily pull the rear wheel without removing these. Lots of room on either side of the slip-ons to the wheel.
Thanks for the positive comments!:)
Looks great. Now you just need some '08 side panels on that thing.
Being in CA I think I would keep the flex pipe in place. This way I can pop 'em off should I get the dreaded "fix-it" ticket.
Good job.
I think he meant the axle will hit the RH pipe before the wheel is free to come off the spline but maybe not. Still, you have to swivel the OEM one out of the way or remove it so there is no difference in work necessary to remove the rear wheel.
