I obviously did not know this. I will have to take another look at mine.There is a spring loaded plunger in the center. It must be freed up to allow air from the vacuum piston chamber into the slow speed/pilot circuit. I bet it's varnished badly. You can get at both sides of the plunger. One side with the air cut cover removed, and the other with the big vacuum piston diaphragm cover and slider removed. Spray both sides with carb cleaner and try pushing in on the plunger with a pick to free it up. If it won't move, let it soak for a while and keep trying.
Thanks for tip about the access via the diaphragm chamber, that allowed me to get the carb cleaner directly where it needed to go , all are moving nowThere is a spring loaded plunger in the center. It must be freed up to allow air from the vacuum piston chamber into the slow speed/pilot circuit. I bet it's varnished badly. You can get at both sides of the plunger. One side with the air cut cover removed, and the other with the big vacuum piston diaphragm cover and slider removed. Spray both sides with carb cleaner and try pushing in on the plunger with a pick to free it up. If it won't move, let it soak for a while and keep trying.
