Yesterday I finally saw some metal showing through on my rear tire, so I decided it was time to get new ones. I stopped at a tire shop and he had Metzler Z6's, Dunlops and the Avalon's. He didn't recommend the Avalons for the ST, and then did a comparison between the Z6's (which he was suggesting initially). He place the front tires of the Dunlop and the Z6 side by side and pressed down on them (this is a "test" he learned from the tire manufactures, apparently called a bead test). This is to determine how much pressure and deformation will occur during a rapid deflation (flat).
The Z6 unfortunately compressed very easily, suggesting that it would have greater instability during a flat. The Dunlop took considerable more weight.
Whether or not this is a valid test for "anything", and considering both tires were the same cost, I went with the Dunlops. Which was what was on my bike before. I'm mildly concerned about the longevity, but we'll see how it goes.
One thing I can say is that having new tires on your bike sure makes it handle differently. I guess I had some mild angles (not necessarily cupping) in my tires, such that making turns required a slight amount of force to push it into it. The new tires turn TOO easily. I barely hint in the direction of the turn and they smoothly and quickly follow the turn.
The tire guy warned me to let them get a little scuffed before cutting in too quickly. My bike is at 9500 miles, so I'll let you all know how they wear. I'd say I'm a "normal" rider in that I don't push my bike too hard, but I don't putt around either. (I rarely go over 6000 rpm). And usually ride between 3 and 4 RPM. Road surfaces around me very greatly between gravel, cobblestone, asphalt and concrete.
