Clearly, I don't post often, mostly an avid reader however thought I would throw in my two cents concerning Dunlop tires. I swore off of them 20 years ago but as of late thought I would give them a second chance......much to my dismay. I was affected by the front tire recall and all went well with that however NOW I have a back tyre issue!!!
Seems the new (installed Feb. but has 4k+ on it now) has a leak.
Turns out the bead area on the tire itself has a quarter inch long, lateral running piece of re-enforcing nylon or the like that was not properly encase in the rubber compound and it seems the air inside has found a way to enter the carcass inside the tire and migrate to this small, expose area of chord at the bead and then leak out at the bead. I found it by immersing the wheel in a deep pan of water. Bubbles where very evident. Let out the air, broke the bead, attempted to clean rim thinking debris might be the problem to no avail.
Clearly a manufacture defect. Will notify Dunlop tomorrow but not counting on much.
Will swear off of Dunlop for as least another twenty years and make those I know and ride with aware of situation.
Curious if others may have experience this.
Regards,
Rotorhead
Regards,
Rotorhead
