Information provided by a Triumph RAT forum member ......
"Just remove the seat, its positioned under the riders seat.
to do so, just lift the end of the seat next to back of the seat cowl and you`ll see 2 x 5mm allen head button screws, unscrew those (don`t fully remove them) and tap the seat backwards to loosen the "hook" that holds the seat to the frame (I usually just tap with the ball of my hand next to the hump, and it`ll slide 1/2" or less), and lift the seat off. total time to do it 20-30 seconds.
To Replace the seat, put the seat back in place, & slide the seat forwards to re-engage the "hook". now the (not so) difficult bit Then tighten up the 2 allen head button screws, this last bit causes some people a lot of headaches, as they try to force the bolts back into place and fail. because the bolts screw into 2 clips, and if you force the bolts, they won`t bite the thread, but just bend the clips. This is the cause of so many seat discussion threads on here
Oh and finally, take a quick look at the 2 rubber bobbins under the riders seat, to see if they`ve located correctly in the cut outs of the cowl either side of the battery, as occasionally the edges catch the seat cowl whilst the seat being replaced, and this can cause them to crack the cowl when the rider jumps on "
