if i understand the design of the final drive it has 2 holes in it, which allows final drive oil to enter the area where the drive shaft splines are located and that oil to mix with the moly grease on the the splines. if that is correct. will that oil return to the final drive with some of the moly grease mixed in with it ?
another question. the engine oil is used to lube the transmission bearings/gears it is a 10/40 weight. that oil gets hot and dirty. but in the final drive 80-90 oil is required which is used to lube the bearing/gears. that oil does not get as hot or dirty. don't the gears in either area have the similar pressure/loads on them ? so why the different weight oils ? not wanting a big debate, just curious.
