I used a gaiter that had a Velcro closure so size didn't matter. They fit all.I am about to replace my leaky fork seals after the Sealmate fix finally stopped fixing them (thanks CYYJ, Dduelin and others who have posted articles on the process). I am going to put some fork protector gaiters on at the same time. For those that have them, what brand & size are recommended?
Thanks!
Yes, thank you for the link.you mean these?
NOJ Neoprene Fork Guards 200
NOJ Neoprene Fork Guards help protect fork tubes and fork seals from rocks, dirt, bugs and road debris and avoid costly fork seal replacement. They are stretchy and durable and will not deteriorate from fork oil. Simple installation with velcro-like back.www.nojgear.com
I have my NOJ guards applied loosely around the upper fork tube, but not over the lower one. It slides around so it doesn't hold any water. Others wrap them tightly over the upper end of the lower fork so they stay in place. They will work either way. Easy to put on, cheap to replace, seems to work well.As the contrarian I don’t want anything holding moisture against the chrome fork tubes. I live in a coastal subtropical climate and the tubes pit easily enough as is.
Whatever seems to make sense and feels good I suppose. If mileage is empirical evidence, I put 180,000 miles on my ST1300 and had no fork seal problems with not protecting the tubes. I guess that means not protecting them works about as well as protecting them? Of course not. YMMV, my bike that had gaiters as OEM protection required two sets of fork seals in 77,000 miles. Does that mean gaiters cause fork seals to leak?I have my NOJ guards applied loosely around the upper fork tube, but not over the lower one. It slides around so it doesn't hold any water. Others wrap them tightly over the upper end of the lower fork so they stay in place. They will work either way. Easy to put on, cheap to replace, seems to work well.
