Did you happen to notice any numbers printed on the springs when you had them out? What oil did you put in (brand and stated weight)? What level did you set the oil to?So after a year of getting ready, I finally changed the front fork fluid as per everyone's instructions (and the manual). The ride is better but I think it is still too stiff. As an example, on the previous BMW I owned, if I would chop the throttle the nose would dive. The ST has never done that. It stays pretty level. So is it normal or did the previous owner (who was about 80 lbs heavier than I am) put in a heavier spring? Just want the front end to so a little better job of absorbing bumps on the road than I think it is doing now.
If the PO put in springs to accommodate his weight and he is 80lbs heavier, Your bike will ride stiff.
