KSW:
If you sequence your troubleshooting & fault-finding activities correctly, you might be able to solve your problem with no Tupperware disassembly at all.
Here is how I suggest you approach fault-finding... you will need a 5 mm hex key and a 20 cc plastic syringe. You can get the syringe at any drugstore for about $1 - you don't need a needle on the end of it, just the plastic syringe.
Put the bike on the side-stand, then, release the gas cap by unlocking it. Now loosen and remove the three hex-head bolts that hold the gas cap assembly in place. There are 7 bolts around the perimeter of the gas cap, but only 3 of them are used to hold the gas cap onto the tank. These are highlighted with green arrows in the picture below.
Once you have the gas cap assembly off, clean up the recess in the top of the tank - get rid of all the dirt & crud in there. Now fill the syringe with some warm soapy water, and fill up the 'moat' around the hole in the top of the gas tank. If the drain hole is free and clear and no hoses are kinked or blocked, the water will drain quite quickly out the bottom of the motorcycle. I think that the drain hose is the shorter one identified by the arrow on the left of the second picture.
If the water does not drain, or drains slowly, manipulate the end of the drain hoses under the bike, you might be able to clear a blockage if the blockage is at the end of the hose.
If no luck, then you will need to lift the gas tank and see if the blockage exists in the tank itself (in the metal tube within the tank that leads from the drain hole to the outlet labelled 'DRAIN' in the picture in post #3 above), or if the blockage is in the hose that connects to that outlet. Disconnect the hose from the DRAIN outlet, and use the syringe to squirt a little soapy water into the drain inlet up by the gas filler hole - see if that metal tube is blocked or not. If it is not blocked, then use the syringe again to squirt water down the rubber hose. If you don't get any water coming out the bottom, investigate the hose run for kinks or blockages.
Save the syringe for later use - it is very handy to have one around for emptying brake and clutch fluid reservoirs, etc.
Michael
Gas Cap
Green Arrows highlight the "real" fasteners to remove - the other 4 are just decorative, don't try to undo them!
Drain Hose Outlets
