Not sure what’s going on with my 91 ST. It bogs down and cuts out after running for a short period of time, like it’s starving for fuel.
It has an aftermarket fuel pump on it with a regulator in line after the inline filter. When I turn the ignition key, there’s no longer the hum of the fuel pump. And when I disconnect the fuel line going to the carbs and turn the key, I no longer get a short stream of fuel, as it usually does. There’s 12V across the leads going to the pump with the key on. And when I connect a line from the battery directly to the hot lead going to the pump (top of the tank), I get a flow of fuel. So, the pump is working, I guess? I even tried a back up pump (same brand as the after market one in it…quantum), to no avail.
I’m a little stumped here…could it be a relay? Any other hints/suggestions welcomed…
Also, It has a new battery and plugs and seems to be getting good spark, as well….
