I was following the instructions from MileHigh with service manual as backup. I am using a vacuum type bleeder. The front brakes went smooth, no problem. Removed plastic to get at the Proportional control valve and removed the left hand front brake caliper. Set caliper at what I thought was the correct angle - much like shown in photo - but I could not get it to drain. I tried different angles with the front caliper but no go. The rest went OK until I hit the last bleeder. That would be the rear caliper back bleeder. It would not drain as well. I pumped the foot brake pedal and then it did drain with each pump - I had to keep pumping it until the oil cleared up.
Has anyone has this happen to them?
ps - I did not try to pump the brake pedal when trying to drain the proportional valve because with the caliper off I did not know if the pads would move. I did not have them blocked.
