I have a Helibars tour performance riser on my ST1300, model hc0303: 1" taller & 2" back (not sure if this is a Gen 1 or 2)
The design prevents you from loosening the fork caps when you have to remove a fork as there's just a bit of the mount that covers the 17mm hex on the fork.
You need to remove the bars AND the Helibar riser to access it.
I'm thinking about trimming it back so I only need to remove the bars from the riser, and not the riser too, in the future.
Anyone see any issues with why I shouldn't?
The bars do cover the area of riser that I'm thinking to remove material from, but I don't think it's really taking any pressure from the bar. What I'm unsure of is will it weaken the area around the bolt hole for the bars.
Basically remove the red circled area cut around the green line. I won't be removing any of the raised shoulder where the bolt goes though, just some of the lower lip area (to the right of the green line.)
