Shoei didn't allow their helmets to be tested.
However, you can make some assumptions based on the outcome of the tests they did. That is, the harder the shell of the helmet, the worse the outcome is likely to be for your head. This basically means the better a helmet does on the Snell tests, the worse it is likely to protect your head against the kind of shock prevalent in MC accidents. (Ya, I was shocked at that, too)
Basically, the reason is that the more flexible helmets transmitted less shock to the head because they absorbed more shock in the helmet shell. The fiberglass and other hard laid-up helmets did way worse than the cheaper polycarbonate molded helmets. The best helmet in their test cost under 100 bucks.
Best helmets in their test results:
Z1R: ZRP-1 (152G's) , Fulmer ADF-4, Schubert s-1 (161G) AGV: TI-Tech, Suomy Spec 1R (182G's)
Worst: Scorpion EXO-700 (211 G), HJC AC-11(204G), Arai Tracker GT (201 G's)
So, one would expect that the hard, laid-up Shoei's wouldn't do very well on the tests they did.
Personally, next time I look for a helmet, I'm going to try on one of those Z1R helmets.
