I have an '04 ST1300A that has the MCCruise electronic cruise control installed, which worked perfectly up until very recently. Now, however, it won't engage, and I'm having a hard time identifying the problem.
I had the rear wheel off recently for a tire change, and I thought maybe it was a problem with the speed sensor. But I ran through the speed sensor diagnostic routine per the MCCruise user's manual, and it appears to be ok. I also had the right side tupperware off recently to bleed the brakes, but I can't imagine what influence that might have.
I've run through a good portion of the diagnostics:
- Computer test ok (lights come on like they're supposed to)
- Vacuum test ok
- Switch test ok
Where I see the first problem with the diagnostic test is the step where you put it into diagnostic mode, start the engine, then press the SET and RES buttons, which is supposed to raise and lower the engine RPM. Nothing happens.
If I understand correctly, I think my next step is to check the voltage on the red wire at the connector that's inside the vacuum actuator unit. I haven't done that yet, because it looks to be quite a chore to get at the connector. I think I need to take the vacuum actuator off to disassemble it, and that looks a fairly involved process. I'll do it if I have to, but I thought I would solicit some experts before I dig into it.
Any ideas?
TIA,
Scott
- Vacuum test ok
- Switch test ok
Any ideas?
TIA,
Scott
