martechy
First let me thank all of you who have posted your problems and what you found to be the cause. I have learned a lot and hope I can aid others with my post.
The problem
My 1998 ST1100 is backfiring up through the carb's.
At first I thought it was the road I was feeling but soon found that the noise and knock was the bike itself. Just around 2000 RPMs it starts knocking.
Shop said it was most likely the carborators, but I didn't have the money so I took it home and took it apart...I am good at that but not so good at the putting back together part.
I found the # 2 carb jet was totally blocked. Cleaned all four carbs. I did not remove the pilot screws. Installed new air filter/fuel filter/and spark plugs.
Put it all together again and started it up. Still backfiring. I removed the spark plugs and all four were coated in gas. See picture.
Help! I may have not seated the carborator well enough on the boots but sprayed some starter fluid around and got no response. Could I have both fouled jets and a faulty ignition timing?
What would you suggest?
Monica
The problem
Monica
