well this is my second ST1300 with idle problems the first one was throttle bodies but it looks like it could be the same problem again.
The throttle bodies have a sensor attached called TPS throttle position sensor it seems this is the cause of all evil.
The problem is you can't just swap out the sensor you have to replace the whole throttle bodies unit as one which is nice and expensive.
If the TPS sensor fails it can cause all sorts of rough running problems over fuelling and low idle and stalling.
I also read in ride magazine this month that the honda CBF1000 also suffers from engine management problems it states that the fuel injection is normally very reliable on the hondas but some customers have had problems with throttle bodies sad thing is the throttle bodies are probably fine its the sensor that is fixed to them TPS that has failed.
Some CBF1000 owners have even got hold of spare throttle bodies just in case it rears its ugly head and my ST1300 06 had the same problem as it worked perfectly for the new owner after they swapped out the throttle bodies. Now I have the same problem again so it would seem on my 09 ST1300 we shall see.
