drrod
Need some advice. I have a persistent ignition "tick" running with my Valentine one.
Setup:
Valentine running through their remote audio module. The module is then hooked into a Stacom 1 Advanced using Starcoms proprietary cable. The Valentine is powered via a Centech relay and Fuse block. The power runs through the module to the detector unit. The relay is grounded through the fuse block to the frame of the bike. If I take the remote audio module off the bike and hold it a few feet away the ignition "tick" goes away. As soon as I get the remote audio module anyway near the bike, the tick returns. I can run the cable on the bike and there is no tick. The remote audio module seems to be the issue. The Stacom requires that the remote audio module is used, therefore I cannot simply bypass the remote and hook the Valentine directly to the Starcom unit.
Any thoughts?
Thanks
Rod
Setup:
Any thoughts?
Thanks
Rod
