This is an "assumption" I made based on information in the Honda Service Manual. Take a look in the General Information Chapter 1 Torque Values. Under standard torque values it shows 7 lbf-ft for 6 mm and 16 lbf-ft for 8 mm. However, with regard to the rear disc bolts, 8mm, the manual calls for them to be torqued to 31 lbf-ft. There is also a note under Remarks for Note 6. Note 6 reads "ALOC bolt/screw: replace with new one." So, here is where my assumption comes in; Since the bolts are torqued 15 lbf-ft over standard and they are calling for new bolts to be used my assumption is that the bolts have been over torqued to set the load and thus stretched. Another part of my assumption is that there is a Note 2 that reads "Apply a locking agent to the threads." yet it is not used for these and many other fasteners. So if the bolt was expected to be stretched and replaced every time it must be a torque to yield bolt, otherwise they would have just given it a remark with Note 2 listed instead of Note 6.
I could be wrong but that is my reasoning. As a side note, like a lot of you I inspect and re-use bolts 99.9% of the time as long as there are no visible signs of fatigue or stretch. I have had 1 front caliper mounting bolt stretch after many times in and out. I was lucky and felt something was wrong and removed it to inspect and discovered the stretch that wasn't there before I tried to re-use it.
