Erdoc48
- Joined
- Jan 25, 2009
- Messages
- 1,410
- Age
- 60
- Location
- Myrtle Beach, SC/ Sometimes Colorado
- Bike
- 94/00/04 STs, FSC600
Hi Everyone,
Looking for some insight on an ongoing issue with the indicators on my 2000. In the past 2 years or so, when the indicators are activated, one of 2 things occur (and it’s on both sides):
-I have to hold the switch in position to keep the indicator light on until a few uses of the switch, then it works as normal
-I activate it, no light, but I hear the relay click rapidly and a few seconds later the indicators blink in normal fashion
So, the switch seems to work to send signal to the relay which clicks rapidly, then eventually the lights work. This is not that common in the warmer weather, usually when it’s colder out as it is now.
I warmed the switch with a hair dryer to see if it was a problem with contact at the switch but that didn‘t help.
What I’ve done so far:
-replaced relay (the one from Partzilla, so OEM equivalent)- seemed to help briefly but then issue returned
-opened up the indicator switch, cleaned out all of the old grease, cleaned the copper contacts with CRC QD contact cleaner spray reassembled with apparent brief improvement then the issue comes back
-opened up the bike (false tank and air cleaner to get to the 4 multi pin plugs) and opened them all, cleaning them with the QD spray- still happens.
-took all the bulbs out and sprayed the bulb housing (electrical contacts)- still happens
That is the whole circuit I would imagine, no? It seems like there’s oxidation somewhere in the circuit when warm, the electrical bridge is OK, but when cool, no connection until ’pre-activate‘ the indicators in the garage, then on the ride all is well (so once warm or the electrical signal is good, it continues to work normally)- never had this issue on the 94.
So what am I missing? Oxidation/resistance at the fuse (haven’t tried that one yet)?
Thanks for any suggestions.
