Insta360 X3 Camera on ST1300
Orange County California
2006 ST1300A
Is anyone here using a Insta360 X3 camera mounted on your ST1300?
This is the type of camera that Itchy Boots uses.
I don't see very many choices for mount locations on the ST1300.
Especially with saddle bags and top case attached.
If you are using one, please tell me how you are mounting it.
-J
I remember somebody talked about making a custom mount for his camera. It was not a 360.
I'm not running a 360 camera. The 2 cameras I do run are helmet mounted for forward and tail mounted under the top case for the rear view.
Ram mounts for the clutch / brake fluid reservoirs is one option.
Ram mounts for the clutch / brake fluid reservoir mounts are another.
There are also a few dash mounts that take a ram ball, but the windscreen would be in the way of a 360 cam.
Personally, I'd definitely go with RAM mounts.
The Insta360 (whatever version) usually comes with an extendable / telescoping selfie stick, which can be extended over or around the windscreen, especially if lowered.
I have the clutch reservoir RAM mount (seldom used), and we've all seen the center mounted RAM balls that come with some bar risers, and there's a mount that can be added to the steering head nut location.
When you see Noraly's videos, we often see her 360 cam sticking way outside the cockpit on the pole, and hers is usually mounted near her right grip on the bar.
