Smudgemo
Intermodal Man of Mystery
I did some searching but I'm not sure how to ask the Great Gazoogle on this one. Yesterday I went to run some errands on my '96 1100, sunny day, 60*, started fine and made it to my first destination about 15-20 minutes from home. Started fine for the trip over to Home Depot about ten minutes away. I'm ready to leave and my wife calls and says get home quick, so I go to start the bike and it declines.
Something loose or intermittent seems to be at play. I can't recall the exact series of events, but it involved all the dash lights not working, then working but dying when trying the starter button (this included the clock.) I assumed the battery had died because the starter never kicked in, but at one point I turned the key and everything worked as it normally does and the bike fired right up. This was over the course of five minutes or so, so not much additional cooling down would have occurred.
The battery is under two years old if the PO was accurate, and the connections should be good as I just cleaned/silicon greased them a couple of weeks ago when I installed heated grips. I keep it on a charger in the garage, and it has never once failed to turn over. Seat of the pants testing with the tender shows the flashing green light that moves to solid green fairly quickly when I get home and plug it in, so no big drains that are obvious.
So I'm trying to figure out where to start. I've got designs on doing the ignition bypass mod at some point this winter, but I don't have the parts on hand at the moment, and obviously not going to fix anything if that's not the problem.
Thoughts?
Thoughts?
