Is 41 mpg on my 2001 ST1100 a bit on the low side?
MotorBikeMike
Tampa Mike
Tampa, FL / Athens, TN
ST1100/ST1300/Norton
I'm into only my 3[SUP]rd[/SUP] tank of gas on my “new to me†2001 ST1100 with 71k miles and the first two tanks came in at 41 mpg with fairly mild riding mostly back hi-ways and interstate at the legal speed limit. (Although I did accidently see 105 mph - and realized the tires are balanced nicely) I have been under the impression that I would expect the upper 40's or maybe even 50 mpg if being very easy on the throttle.
The brakes are not dragging so I can rule that out. My next thought is to look at the carbs and perhaps get lucky with just a sync. Any thoughts?
Thus far all I've done on the bike is changed, oil, tires, and rebuilt the calipers and add new pads.
-Dirty air filter?
-Tire pressure low?
-Lots of short trips?
-Enrichener not fully released?
My 1991 is stock. I get low 40 mpg on combined city, rural riding, very high 40 mpg highway only riding. I do see low 50 mpg when I can catch zero alcohol content gas on trips.
fuel economy is more a function of the number of times you stop/start than anything else, so its hard to pin it down to any particular mileage figure. And when in touring mode with little or no stopping it becomes a function of speed (and wind, if any).
I get about 40-42 with mine for general around town riding with a mix of freeway and sideroads, so if that's what you were doing it sounds about right. If I ride at a steady speed my mileage rises up to as high as 50, and is never less than 45. If you weren't stopping at all, or very rarely, then 41 sounds a little low.
168K on my 2002 ST1100A & I average 41mpg. I've been anal about checking at every fillup. Highest I've seen out west, where they have better fuel, is 48 mpg. I have found no difference between using 10% ethanol & undiluted dino juice. I have heard earlier models get a little better fuel mileage.
I did a couple long rides with dwalby and he always got 2 - 3 mpg more than me. He likes to say it's because he slows down less for turns :cool: which may explain part of it. I also had a slightly larger windscreen which I believe had more to do with it. When commuting on I-10 in California probably averaging 75 mph, I averaged just under 40 mpg. When in a meandering mood on lower speed 2 lane highways, I got as high as 50 mpg. Truly ymmv
I only get 33 Miles/Gallon on my St1300 2007. (0.72liter/mil). Love fast accelerations and have a short ride to work.
I’m into only my 3[SUP]rd[/SUP] tank of gas on my “new to me” 2001 ST1100 with 71k miles and the first two tanks came in at 41 mpg with fairly mild riding mostly back hi-ways and interstate at the legal speed limit.
So , at what speed were you mostly riding at ? I get about 42 mpg @75 mph, and about 56 mpg @ 58 mph.
I never did better than 35 on my '11. But my right hand never really got out of the "happy zone" when riding it.......(get your minds out of the gutter)
I probably do better on the '13, around 40, once again, happy zone.......
My 99 averages 45 mpg, my 98 is getting 53 mpg, I'm happy with that!!
These guys are talking about US mpg,so 45mpg is around 37.5 mpg US,
I can never get the mpg they get, shorter journeys and too much throttle are the likely causes!!
I get around 42 mpg avg I suppose,thats 35mpg US.
Hal and I would compare mileage between our ST1100s and later our ST1300s on WeSTOC trips. On both bikes I always seemed to squeeze out a few more MPGs than Hal. I always wondered what would be the effect if we switched bikes over a few tanks of fuel.
I get around 42mpg when the bike (1990 ST11) is ridden in a "brisk and spirited" manner on twisty roads with plenty of braking and acceleration, usually in the 70-80 mph range. I'm sure I could get a much better result on a long highway run but I'd probably die of boredom first. No ethanol in our fuel.
The two tanks of fuel were back hi-ways in flat Florida - well I did hit an elevation of 240' : ) - and speeds where mostly around 50 -60 mph thus from what I'm seeing in your post I have some sorting to do, but it's not urgent. I also should check out my Odometer and speedometer with my gps phone to be sure my numbers are right.
Thanks for the info.
on a 4k trip, heading west got 42 mpg. Heading home, east, got 48mpg. Best I can figure is tail wind.
that and the fact that its a gradual uphill traveling west and gradual downhill traveling east.
My 92 got 47mpg at 85 mph indicated like money in the bank on trips and 40-42 riding seven miles to work...
