On the front master cylinder sometimes it’s possible to clean the return hole with a torch tip cleaner or small piece of wire. Does anyone have a shortcut method to clean the return line on the rear master cylinder? The symptom is the rear brake pretty much locks up after using a few times and cracking the bleeder nipple will release the pressure and brakes are free again. Thus we know it’s not the caliper.
I may have to pull the peg mount and remove the master cylinder and do a full clean and maybe a seal kit while there, but if there is a shortcut I’ll try it.
Thanks
Thanks
