Have recently run into an issue with my otherwise normal performing Audiovox CC. When setting the initial 'hold' speed with the throttle engaged (ie holding desired speed), it would always taper off before speeding back up to the set speed. Lately I have been releasing the throttle from a faster than desired speed and hitting the set button; positive immediate pull to desired speed.
But now it seems the unit is 'losing' the setting because regardless of how it is engaged using either of the two previous techniques, the motor does a slow reduction of speed until it starts lugging (due to set point reference I suspect, not due to engine speed vs gear) until it drops off completely and the bike returns to idle. Fix for this has been to either cancel and resume, which seems to work best, or cycle power and retry, which doesn't always help.
I don't suspect a vacuum leak because sometimes, like this morning, it works just fine. That seems to be in the higher RPM range (4k-4500 to hold above 70 indicated) vs slower; can't seem to get it to engage at all at lower RPM anymore but it used to do that just fine when newly installed as well.
I do not have a vacuum canister installed; made one but never put it on and didn't have any problems until now so don't suspect that either, but am willing to try it if it'll help. Just haven't gotten under the airbox since I put it in; will replace those nasty air horn/nozzle screws when I do per the thread on this site.
Sometimes it doesn't 'like' going downhill and will slow down/speed up repeatedly until it gets into the lower portion of the control window and starts to lug/loses the setting completely again, similar to above. Other times, like this morning, it hums right along uphill or down, never wavering more than about 200 RPM from the set speed.
I have reviewed the rebuild thread on the site and have considered that as a possible cause (dirt or functioning of the valves on the vacuum container?) but haven't yet taken the plunge to pull that particular item for inspection.
Any thoughts/ideas as to what might be going on here would be greatly appreciated!
Thx in advance.
Gus
Thx in advance.
Gus
