Have to do some work on my son's bike; it has sat for awhile and we drained the gas yesterday (it sat w/ ethanol fuel in it...yes, I know, shouldn't have let it do that, but we're where we are...) but before doing so, started it up again and it still doesn't want to roll off the idle stop without dying. I assume it's a carb jet problem, but don't have a sonic cleaner and haven't ever had one apart before to know what to look for aside from taking the bottom bowl off to see if the float moves freely on the main jet (I assume it does since it started and ran long enough to feed) and whether there's any grunge in the bowl itself. Plan to use carb cleaner but haven't sprayed any into the engine before starting disassembly to see if that would help. Figure that would have been more of a bandaid to the symptom than a healing action anyway, and I want to see what the carbs are all about for my own education in case we run into more issues down the road now that he'll hopefully be riding it more.
Plan to mark the throttle adjustment and any needle valves (turns in to seat then write down to reset upon reassembly, if taken apart) but what else is there to look for as a problem/general maintenance on a carb'd engine? Been only working on my ST, so this is a learning curve for both of us!
Plan to change all the fluids as well, so shouldn't be any issues there once we get it running solid again.
Thanks in advance!
Thanks in advance!
