Hi guys......ok I'm the first to admit that I am NOT a pro-wrencher; rather I know just enough to get myself into trouble!!!!
I'm trying to install a Kisan SM-3 Signal Minder. This group told me where the signal/hazard flasher is located. I found it and replaced the relay with the Kisan (plug n play). I even added the recommended ground lead to the wire block. It just wont work!! Nothing nada zilch. I tried a different ground location, tried it w/o the added ground ....nothing. Re-installed the original relay and all is fine. Truly disappointed as I was really looking forward to NOT feeling so SENILE everytime I forget to turn off my signals...LOL
I called Kisan's Tech line and got a courteous reply a little later. The tech states that I was using the wrong relay as it is ONLY for the hazards. The signal relay is under windshield. Well before I stripped down the nose I decided to check the SM. I dont see any signal relay for the 2004 ST1300 under the windshield.
Really could use your input here....THX!!!!:bow1:
