Okay...I am throwing up the white flag and I need some help. Here is my story, 2003 ST1300 knock sensor fault codes. Change the sub wiring harness, still has codes. So I decided to use my manual and check the wiring. Spent hours looking through posts to make sure I use all the tips I can get. Pull out my service manual, look at the electrical diagram and it shows G/O and R/Bu as the wires I need to check. 5-46 of the manual says the left side wire is Blue-Blue to check the connection. I dont have a blue wire in my connection going to the ECU. 5-46 of the manual says the right side is R/Bu but in my harness at the knock sensor, the wire is black. While checking my black connector (picture) I found 3 wires that have continuity to ground marked with red line. So what wires at the ECU actually go to the knock sensors? My goal is to run another wire to both sides just to make sure I dont have a wiring issue. I read posts that the diagram is wrong but was fixed later and then I read the right side is actually black. Not sure where to go from here.
Thanks in advance.
Thanks in advance.
