As many of you know I have been testing(experimenting) with using LED Headlights with a SDC Modulator.
I have two sets on two bikes. My commuter bike, the Headlight/Modulator are still working just fine.
But, on my 2012, it's a different story. I just got back from a 4,800 mile ride on the 2012. Everything seemed to go well for the first day. On the second day I started noticing my headlights were going off/on on me, no pattern. I made it up to Idaho Falls where I removed the modulator completely. At that point I had both headlights still working.
When riding up Pike's Peak, the left headlight went out completely, no high beam, no low beam.
After doing some testing, I removed the LEDs completely and replaced them with some H4s I bought at a local auto store. No more issues.
I'm "guessing" that the problem was from continuous voltage thru the modulator to the LEDs and some how it caused the modulator to fail, and then one of the controllers from the left LED failed. Too much heat or something? I don't know.
The LED/Modulator on my 2010 is still working just fine, but it is only used in short spurts (1.5 hours at a time). maybe that has something to do with it, I don't know.
So, now I have one LED headlight and a modulator out of commission.
I think I'll look around to see what is out there for LED Headlight modulators. I've been told of a couple so far, but if you did what I did, be mindful if you are riding any distance with this combination.
