Location of turn signal flasher unit or fuse.
Bowmanville, Ontario
2005 Honda ST1300
I recently installed a new battery after the not so older one failed to take a charge. Each time I put the charger on the battery it set off the alarm system and the lights flashed. After installing the new battery everything except the turn signals and 4 way hazards worked. I have the smart brake and turn signal cancelling unit installed. Does anyone have the solution to this problem and can someone tell me the location of the fuse / flasher control/relay , pictures or diagram would be nice, until then my arm/hand signals seem to be working just fine.
Location is under the side panel where the lift assist handle is.
This may also help with the wiring as there is some info on the fuse.
