It's a slow process as your throttle gets worse and worse. You don't notice it. Mine was at the point that it literally took a second to close from full throttle.
Now granted I had to remove the airbox etc. and remove the cables from the pulley but it was worth it.
I used a pressure luber with the original -70 spray that came with it 30 yrs ago.
Now the throttle snaps closed again like it should.
Still have the brake/clutch fluid, and coolant change to do then put her back together.
