HOHOHO It's below freezing and snowing. Not only that but when I pick up the breadwinner at 4:30 it's already dark (almost)!
I have a box of stuff to install on my NTM '04 and am slowly stripping it down to the nitty gritty now that it's in hibernating mode. As much as I enjoy researching old posts on the forum I have found that a search on the 'MCL Fuse Block Mount' seems to hit every post that has been made by someone who has 'MCL Fuse Block Mount' listed as a farkle on their profile.
So .... since I am going to order Eastern Beaver's block I'd like to have the MCL plate in place (so I can order the appropriate leads at the same time).
I know that if I keep looking through posts I'll find some advice on the MCL plate position but it's Dec 2 and Christmas is approaching. Can someone help me out with a tip? This mounting plate is designed and pre-drilled to take about every option out there. Is there a spot under the rear seat where I can simply screw it in (like above the tool kit) with the supplied hardware?
The MCL site says
"The 2 main mounting nuts are 8mm to fit either the stock rear cover or a top box mounting application". Did those of you who have installed the MCL find a good spot and did you have to drill? I have an aversion to drills ever since I saw Marathon Man and hope to source a 1300P right switch for the other end of the winters farkles to keep the switching neat (and the plastics intact).
I have found one thread that implies the 36" Eastern Beaver lead is the right one for an under (rear) seat rear location and may simply go with that so I have what I need to begin mucking.
Thanks guys for any help you can give. If you installed the Eastern Beaver block on the MCL plate and are happy with your location choice ... or if you did it and wish you would have done something a little different I would appreciate your response.
Happy Holiday Shopping. In a perfect world we would all be able to do it on our ST's.
The MCL site says
