Since these are both "upgrade" versions, I thought I'd document the pair. My objective is a high-mileage set of tires that don't suck. I know I will be leaving some performance behind, but with the kinds of mileage I am getting on Bridgestone T-31's I'm leaving my behind behind. The Commander III is an upgrade to the Commander II and the BT-046 is an upgrade to the BT-045. Both promise better mileage than the earlier versions. Both bias construction. Stock non-ABS sizes 160/70-17 rear and 110/80-18 front. Here's the set...
Impressions so far... Both are heavy tires. I didn't notice a difference from the weight in the rear, but the 3 or so extra pounds in the front did have an effect on suspension compliance over rough ground. It wasn't bad, but the degradation is apparent vs. the T-31. Otherwise, the set tracks and corners well, and is without bad habits. Both tires are quiet. Good cornering confidence. Steering isn't as precise as the T-31, but it is at least as good as the G547. Hands-off straight-line stability is good with no hint of headshake. It is hard for me to rate installation difficulty any more because the Weaver machine doesn't complain. However, I'd say the Commander III is on the order of a BT-020R or ME880 in stiffness. The BT-046 went on easily. In fact, I rolled on both beads at the same time with one revolution of the machine. I can do this with some, but not all front tires. I haven't been able to do it with wide rear tires. I mounted the BT-046 backwards vs. the rotation arrow. The sidewall says "Rear Use Only". Silly tire engineers. If you are going to do things backwards, just go ahead and do them totally backwards. All factory advice that I have found (only Avon) suggests reversing a rear tire when running it on the front because that is the direction of tread ply overlap and because braking is the main force on a front tire vs. acceleration for the rear tire. The rear took 2 oz. (eight segments) to balance and the front took 1/2 oz. (two segments) to balance. Only the front had a stem location dot, but I didn't use it because I have pre-balanced my wheels.
