Michelin Pilot Road 3 on ST1100
Las Vegas, NV
2002 ST1100
I just put a new set of Michelin Pilot Road 3's on my 2002 ST1100 and noticed that the RPM has risen about 125 to 150 at a given speed. The new tires are:
Front: 120/70 ZR18
Rear: 160/60 ZR18
the old Dunlop's were:
Front: 110/80 V18
Rear: 169/70 V17
Is there any reason to be concerned, e.g., indicated speed difference, reduced fuel mileage, increased wear, lower overall aspect ratio, etc?
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
Only if you are really pinching your fuel pennies. I would say to just enjoy the performance of the tire and smile all the way to the next fill up.:)
STArnie13
R.I.P. - 2020/07/03
Wichita, Ks
The new front tire should not change the speedo reading but the new back tire is a bit smaller causing the rpm's to go up some. That small an rpm jump shouldn't make much if any difference in mileage on an 1100.
Versailles, KY
2018 GL1800 Airbag
8693
Even with 170/60 the kickstand is a little too long. You have to be careful how you park it. Mine fell over once when I didn't notice the slope. Other than that, no problems. Next time I'm going with the 160/60 to lower it a little more. I've already shortened my kickstand to compensate for my shorter shock.
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
7910
Good point, I shortened mine about an inch I think. Just cut it below the spring, bevel both ends and have a good welder join them.
