kappy5003
About 14 months ago while working in the city I took AnaSTasia off the road as she wasn't quite running as smooth as she used to.
I decided to do fork seals,shims, radiator hoses, some leaks plus tyres and do all fluids.
Anyway around November last I experience a tragic family event that gutted me so everything went on hold, so a few months ago I put her on a trailer and brought her home as therapy.
Its been a long slow road.
After sorting out some battery issues I finally fired up AnaSTasia. It took a while for her to start but when I did I could tell all was not smooth and there was heaps off black smooth as I revved her, probably flooded her. I also noticed more tappety than before I did the shims.
When Idling and when revved slightly I could tell it was not quite smooth, like timing not right, so too hard leave for another day.
So the next day when and fired up 1 st time tappet noise almost gone but still not smooth.
I checked the spark plugs ( Iridium that I have had for about 20,000kms) they were all quite black
Since then I have started her a few times seems as if getting a little better. New fuel--carby cleaner.
Any way a couple of days ago I got to operating temp and noticed running better when warm, so did carby sync some minor adjustment not really a lot, less than I would have thought.
The following day I fired her up again, Wont fire without choke when cold and it not that cold really, anyway got temp up not as warm as the day before and checked carbs and discovered quite a bit of discrepancy. Thinks out loud, I look at that later.
A few days ago I started her with a little choke and notice a little backfire though carbs, even with choke off still a little backfire. Increase revs a little and can here a little popping, all with air cleaner cover off.
I also smell what I call a pepper type smell from around the intake area, I related this smell to a sort of coolant smell , takes me back to an old car I had with coolant leak car heater system.
Yesterday I decided to obtain some standard plugs and on removing Iridium plugs noticed they are still black and quite damp.
After installing new plugs when starting I observed popping through intake but also noticed when revving slightly popping from all intakes plus felt as though more sluggish than before but slightly smother ,does that make any sense???
So before I start ripping everything apart unnecessarily can I ask a few opinions factual would be a nice, I feel may be necessary to pull carbies out etc.
I know plugs should probably be greyish and not damp.
Almost just now.
Choke cable and operation, checked and OK.
Ran for short all pipes hot.
Pulled No 3 plug quite wet at base of thread.
Pulled No 2 & 4 both black on bottom electrode ,No 4 more so, all plugs are new,minutes old.
Side note prior to taking off the road the engine didn't feel as sweet and smooth as she did say 5000km before, hence the reason for doing shims.
She has sat and not been started for approx 14 month hence carby concern.
Shim settings double checked and ok.
On just starting convinced I have a coolant leak that I can smell but can't see, ----more exploration
Cheers
Kappy
Almost just now.
Cheers
Kappy
