Motorcycle Lazy Susan
Nebraska
I posted something about this on another thread but figured it could use a thread of it's own so here it is. I have to take tons of pics of a variety of different motorcycles and ATVs at work so I decided to build my own lazy susan to make my life easier. My inspiration was a youtube video I saw of someone using a pair of motorcycle ramps bolted together and attached to a lazy susan that a guy used to roll his big cruiser onto and put his feet down to spin the bike around in his garage so he didn't have to back it out and turn it around in the driveway.
I used were a $9 lazy susan from the hardware store that's normally used for kitchen cabinets and bolted it to a metal frame that was the top of a shipping crate for a Yamaha Grizzly ATV. I added a piece of 3/4" plywood with a smaller piece hinged on each end to act as ramps for rolling the bikes on and off and some indoor/outdoor carpet to make it look nice for the pics. I then added a small ball bearing caster on each corner to keep it from tottering as I loaded the bikes on and off. All together I have well under $100 invested in it and it looks very professional and makes my life much much easier. Even with an ST or even a giant GL1800 Gold Wing on the spinner as long as I use the center stand I can easily spin the bike with my foot. Since I also load plenty of big heavy cruisers w/o center stands and ATVs I added an I-hook to attach a heavy duty dog leash to help spin it around when needed.
I realize this is probably overkill for most of you so you could easily make a much smaller version to use with the center stand with just a small square steel plate attached to the lazy susan and just put your feet down to spin your bike around in the garage. If I had a bigger garage that wasn't so full of motorcycles and other junk I'd build one for myself to use at home. Here is a series of pics of a 2008 ST1300 in action on the spinner.
2008 Honda ST1300_001.jpg2008 Honda ST1300_002.jpg2008 Honda ST1300_003.jpg2008 Honda ST1300_004.jpg2008 Honda ST1300_005.jpg2008 Honda ST1300_006.jpg2008 Honda ST1300_007.jpg2008 Honda ST1300_008.jpg
Good idea.
I would have thought a kitchen lazy susan wouldn't have been build strongly enough & collapsed or crushed under the weight.
That is one fancy device. Thanks for sharing!
You mentioned your garage is as full of stuff as mine so I thought I would share my solution for packing my bike into the corner. A center stand dolly works really good if you do a couple things. 1) Watch the YouTube video they give you a link for before you try to use it and 2) Drive the front tire of your bike up on a 2x6 that has been cut at a 45 deg on one edge.
http://www.2wheeltouring.net/gadgetsPM.htm
I like the idea of the Lazy Susan, and if space was no issue, I'd have built one already. The center stand dolly works just as easily, and has the advantage of not taking up a permanent space, plus can turn around in less of a radius, if it is needed, with fill and turns, which are accomplished easily with even a VERY heavy bike on the dolly. Also, as AK JAS has noted, you can put your ST in a corner with it.
I like the idea of the smaller (steel plate on a lazy susan) unit, but unless you have a permanent space which is big enough to turn the bike around in, it requires that you put it up on the centerstand, turn it, and take it off. I am not sure the time savings would be there.
I'll use my dolly for the ST 'til I find something better, I still need something for the scooter!!
I have made a few of the smaller ones using 3/16" or 1/4" steel for the plate. They work well once you get it on the center stand. I found it much easier to get the bike up by placing a 3/4" board for the front tire to sit on to get the bike closer to what would have been its original height.
The lazy susan is rated for 1000 lbs and has held up amazingly well. It's been almost a year now and I went to replace the lazy susan a couple of weeks ago figuring the bearings would have to be about shot consider I've put hundreds of bikes and ATV on it but it was still spinning fine so I just added some more grease and put it back together. I did have to replace the ball bearing casters in the corners since they were pretty wallowed out but they're not sealed or greased at all so that was to be expected besides there were only a dollar or two each.
As a person with multiple bikes, some of which ACTUALLY RUN!! i LOVE this idea! would make it easy for storage Tempted to make some myself...
