having a friend mounting a car tire (205/50/zr17) for me and he does not think it will fit without removing final drive. going to have him mount a 205/55/17 or 205/60/17 instead since he thinks he may be able to make that fit. anyone else having difficult mounting issues getting a 205/50/17 to fit?
Search DarkSide , and pick a known tire that has been tried tested and works. There is no need to guess at it as there is lots of good info on this site.
BfGoodrich g-Force Comp 2 A/S plus all-season 205/50zr17/xl 93y - You can get WalMart to order it for you.
I did not need to remove the final drive although that's not really a big deal. You will need to let the air back out and soap of the tire to slip in.
On my older 1983 GoldWing, I remove the final drive to change the stock tire. It's only 3 nuts and much easier than not removing it. However, it's not needed on the ST1300.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
