Working on swapping out a rebuilt shock, I was attempting to get more clearance to drop the swing arm into a side stand mount void and in attempting to remove the left muffler attachment bands going from the exhaust crossover back to the extension the muffler slides into, it broke. They're probably the originals and rusted through pretty good, so no surprise there; should have just left it alone as I ended up loosening the step/pedal mount farther to get the lower shock bolt out (it'll be going back in the opposite orientation as was suggested in other posts).
They're both available online but the left side 18372-MAT-000 for some reason is more expensive than the right side 18371-MAT-000. In looking at them, there are tabs that locate on the clamped pieces but my question is are they reversible, ie, buy two rights and use one on each side? The only thing I can see is that the bolts would be oriented opposite on the one side, which isn't a big deal to me all else being equal. Anyone have experience or know whether a left can be used on the right as well or vice versa for that matter? The parts diagram shows the bolts being accessible from the bottom, but there are several notches the tab could fit into; mine were oriented horizontally (front/back) vs top/bottom where I could see top access being an issue were they mounted that way. Thanks!
***UPDATE*** I went ahead and ordered both from Partzilla, along with the lower shock mount roller bearing, dust seals and insert.
***DOUBLE UPDATE*** Aaaannnndd so back to my original question...the two parts arrived and look significantly different than each other, and from the parts manual:
Single bolt included, no band holes punched
Two bolts required separately, band holes punched
In addition, the parts manual calls for 5 flange bolts but the right side clamp already includes one bolt as a unit; the other requires two, which when combined with the crossover clamp would make for a 5 count. But if that's the case, why the two part numbers/different parts?
These are what I have/had installed; the broken one is off the left, the right is still in place for now:
Does anyone else have the strange looking single bolt clamp above (18371-MAT-000) installed on the right side? Just curious. I may end up swapping back to stock exhausts, using two left side clamps since I already have all 4 bolts, and see if Partzilla will take the other back for exchange of other parts to mount the stock mufflers (the fwd bolts/nuts that I don't have currently).
Not complaining about the quality at all; the broken one was just fine until I tried to take it off. Just a curious situation...back to the project!
Two bolts required separately, band holes punchedIn addition, the parts manual calls for 5 flange bolts but the right side clamp already includes one bolt as a unit; the other requires two, which when combined with the crossover clamp would make for a 5 count. But if that's the case, why the two part numbers/different parts?
