This is a real mystery to me. Hopefully someone else has run into this problem and found the solution. Pressing the start button on the handlebar just makes a click sound, coming from somewhere around the dash - definitely not from the starter relay. It started out with the starter not working intermittently. Then advanced to not at all. It seemed to start when I installed a new set up regular handlebars on the bike. But now I have no idea what caused the problem.
Since there was + voltage into the relay but not out, I first replaced that. Nope. Then I saw the connector at the relay had melted at the red wire connection, so I replaced that and also did the red wire bypass while I was at it. No luck. I had also originally tried jumping across the contacts inside the starter switch but got the same result.
Then most recently out of desperation I thought to jump accross the external soldered wire connections on the switch (blue/white to red/yellow) and bingo, it turned over. So even though that switch is very straightforward and you can take it apart completely, this result to me could only indicate a bad switch (the snap on cover was cracked, so I thought...). So I got a clean used right hand switch assembly on eBay, connected it up and...same problem.
Does the switch assembly need to be grounded or something? I tried that without mounting it but made no difference. This totally makes no sense to me at this point. Hardware/wiring wise there isn't anything left to test. I must be missing something really obvious...or not.
Any ideas?
Any ideas?
