I recently picked up a set of bar risers from @Grand Rouge (great guy to deal with!) and while installing them I was double checking that I had enough slack from the wires, brake and clutch lines when I discovered the previous owners re-routed the clutch line when (I assume) they installed the helibar risers (I am planning on stacking the risers). Even though the clutch line can technically work with some creative routing there is a horrible bend when the bars are turned sharply (full lock is really bad) and I believe this will create a failure point of the rubber clutch line where it meets the rigid steel line.
So... I would like to replace the entire section with a braided steel line and I am looking for feedback as to which company you have used for the braided lines (HEL, Galfer, etc) and if anyone knows the total length of the line (from master to slave cylinder) so I can order a new line a few inches longer.
Also, I am considering doing some preventative maintenance on the clutch slave since I'll need to drain and bleed the system anyways plus with how nasty the fluid looked when I fist got the bike (see the attached pictures, the "fluid" in the before was more like a gel than a liquid). What are your thoughts about getting a rebuild kit for the slave cylinder or would you recommend replacing the entire unit?
